How do you think intel can sort this? The only way is a complete new arch
buy a 9700k or 9600k as these don't have ht lolLooks like it HT related, disable HT![]()
Any of the hyperthreading issues obviously won't impact the 9700k. Three issues have been resolved in hardware in the 9 series and the fixes for the rest are down to patches and updates to the affected os, software, bios or microcode that runs on the cpu.Will all the issues in this thread also apply to the 9700k? Just got the funds to buy a new cpu, mono and ram but don’t want performance killed off over the months with bios updates to fix these issues
Thank you for taking the time to reply. I would wait but my x58 mobo died a few weeks back and now needs replacing. Got a budget of £550 and can just squeeze in a 9700k, 8gb 3200mhz ram and a gigabyte z390 UD moboAny of the hyperthreading issues obviously won't impact the 9700k. Three issues have been resolved in hardware in the 9 series and the fixes for the rest are down to patches and updates to the affected os, software, bios or microcode that runs on the cpu.
There is no way of escaping the issue (right now) because it is so prevalent, however you don't need to install every fix. Weigh up the cost of the fix vs the likelihood that your machine is vulnerable and going to be targeted and decide for yourself if the performance hit is worth it.
There are going to be new exploits going forward as well as fixes for those exploits. Security is a game of cat and mouse. They can predict what avenues of attack might be used and try to mitigate the threat, but until the hardware and software is in the wild you don't know how secure it really is. Even years after release like in this instance.
You may see less issues with ARM or AMD depending on your environment, but that doesn't mean there wont be issues in the future that require fixes that impact performance. Hopefully this isn't the case, in which case AMD is a slightly more secure and viable alternative given that not all the exploits are proven to affect their current hardware.
https://mdsattacks.com/Ironically, the recent hardware countermeasures introduced by Intel in recent Coffee Lake Refresh i9 CPUs to prevent Meltdown make them more vulnerable to Fallout, compared to older generation hardware.
Another reason to go AMD this generation. Intel's architecture is inherently insecure, and even the recent ones still need mitigation.
wikipedia said:The Intel Management Engine always runs as long as the motherboard is receiving power, even when the computer is turned off.
The IME is an attractive target for hackers, since it has top level access to all devices and completely bypasses the operating system.
It is normally not possible for the user to disable the ME. Potentially risky, undocumented methods to do so were discovered, however.[39] These methods are not supported by Intel. The ME's security architecture is supposed to prevent disabling
and another found, but should be patched by now though.
SWAPGSAttack
https://www.guru3d.com/news_story/s..._intel_processors_starting_at_ivy_bridge.html
Im glad i went back to AMD![]()
How are all these exploits happening now when it was never an issue back in 2012... or whenever.
Did anyone ever encounter a hacked system because of these "vulnarabilities" ? Doubtfull.
