Hi, I am having some temp issues with my Intel Core i5-2500K, the idle temp is around 40oC and under full load fit reaches 90+ very quickly. One of the cores actually hit 97oC
. Am using coretemp and speedfan to measure the temps.
I tried reseating the heatsink and applied new thermal paste but it made no difference. I also tried my Thermaltake big typhoon but the temps are still hitting 90 degress.
BTW the CPU is running at standard clocks, and all drivers and bios are up to date.
System info:
Asus p8p67 LE
G.Skill RipJaw 4GB
XFX 6850 gfx
Any help would be greatly appreciated.
. Am using coretemp and speedfan to measure the temps. I tried reseating the heatsink and applied new thermal paste but it made no difference. I also tried my Thermaltake big typhoon but the temps are still hitting 90 degress.
System info:
Asus p8p67 LE
G.Skill RipJaw 4GB
XFX 6850 gfx
I can't imagine the CPU getting that hot unless either something in it is royally broken or you left the plastic cover on something! So I'd suggest physically checking the temperature of the heat sink near the CPU.
