Intel's 13900k's and 14900k's are crashing at an alarming rate? Why isn't anyone talking about it and what is Intel's solution?
Forum Thread here: https://forum.level1techs.com/t/int...k-ks-kf-14900k-ks-kf-crashing/213008?u=autumn
Intel's 13900k's and 14900k's are crashing at an alarming rate? Why isn't anyone talking about it?
Because the press is scared of Intel?
Some reports that Intel is rejecting rma claims for 13th and 14th gen with this issue and telling people they need to run the Intel baseline bios profile
So if your 14900k is no longer stable then you're out of luck and have to use the baseline profile and lose 15% performance
Over the last 3–4 months, we have observed that CPUs initially working well deteriorate over time, eventually failing. The failure rate we have observed from our own testing is nearly 100%, indicating it's only a matter of time before affected CPUs fail.
I dont think so as my 13600K has not been effected by this and I've not seen anything of people having these issues with a 13600K/14600K and below.SMT issue, it's gone for the 15th Gen on the P cores!?
It depends. What do you use your system for. Gaming only, or productivity tasks too?What should people buy instead?
Maybe we should have a CPU ranking thread like we have for GPUs?
mainly web browsing, gaming sometimes, web dev sometimesIt depends. What do you use your system for. Gaming only, or productivity tasks too?
That is one sure easy to fix it!SMT issue, it's gone for the 15th Gen on the P cores!?
What CPU and board are you currently using?mainly web browsing, gaming sometimes, web dev sometimes
