Intel push pin problem
RaV
RaV
17 Dec 2007
Ireland
Ok so ive had the PC in my sig for a few months but only got around today to buying/trying to install a new cooler. Its an Akasa AK 965.
The problem is that i took out the stock cooler, though it was a small Cooler Master one instead of a stock intel.
I couldnt get the push pins to go in, but ive just noticed that there are little threaded screws in the 4 holes. - the Cooler Master had a screw in design as apposed to the push pin set up.
So basically i need to know if there is any way to get rid of them? did i take the original heatsink out wrong?
edit.
Cheers
Conal
Those holes should be empty. I'd get a needle nose pliers and screw them out. Or maybe you have to take something off the underside of the mobo.
I know theyre meant to be empty :p a pity theyre not.
the mobos still in the case, so i can see if theres anything behind those screws.
Ill try to have a more serious attempt with those pliers :)
good thing i went to get some food. what a pain, really not in the mood at the moment. guess ill do it later sometime.
Thats one really stupid design, the cooler weighs nothing at all. damn you cooler masters! :D
thanks Philly :)
:) so how long will it take to take the mobo out and put it back?? the last time i put a mobo in/out was my the pc before this, and that was based on an AMD Athlon 2500+.... :D
