Intermittent POST with A8V-VM
16 Apr 2004
Midhurst, West Sussex, UK
A new build of mine is suffering from a strange problem when it powers on.
Sometimes when it's switched on everything will power up, but no beep, no output at all. When I reset it a couple of times it'll boot normally.
XP 3500
1GB RAM
Just wondering if anyone has any idea what could be causing this.
Thanks
-Chris
What PSU are you running?
Check the 3.3v, 5v & 12v rails in the BIOS or in windows under load and see what they drop to.
Does sound like the PSU isn't strong enough but could be a cold boot issue with your particular motherboard.
If its not the motherboard or PSU make sure the memory and CPU are firmly seated.
Regards,
ghgh
It's an Antec 380W PSU. I will check the voltages...
Under load:
3.3V = 3.25V
5V = 5.18V
12V = 12.09V
-Chris
Those voltages are totally fine mate...it's very unlikely be the PSU now.
Might be a cold boot issue with your motherboard. A BIOS update might help but I doubt it.
Can only pick at straws here but I can't think what else it can be if the CPU and RAM + Graphics card are all seated firmly. :confused:
Has it done this ever since you built it? if so I'd RMA the motherboard.
As far as I know there's no BIOS updates - I tried this a month ago.
And yes, it has been doing this ever since I built it.
-Chris
