- 26 Jul 2010
- Wiltshire
Because you would still have the clearance gap between the door and frame.
Putting it on top of the door takes the top of the door back into the rebate.
Of course, but sticking a bit on the top of the door would look crap unless it was done properly and painted afterwards. Moving the door up would probably make the gap at the bottom massive. This is a rented property we're talking about, if it was owned then I'm sure the op would want a new door and the job fixed properly.
The way I suggested is the quickest & easiest for someone who perhaps doesn't have the best DIY skills to just get rid of the actual gap. And yes, it's a bodge I'm well aware, I am a carpenter by trade. As it happens I'm making solid hardwood doors for one of my clients at their manor house I'm currently working at.
