Interview for new job - what should i say for 'why i'm leaving role?'
16 Apr 2003
UK
I actually posted on here about my current work situation a month or 2 back but removed the post after getting advice, generally along the lines of voting with my feet which i'm doing.
Long story short, i moved 125 miles for a new job/company and the day i got there they said that i won't be given the job i applied for and that i will be given a different job on the same pay however. The job sounded awful and in fact, 9 months in it's worse than i thought it would so i need to get out.
No apologies from them or anything, just a total waste of time and they have trapped me in London as i signed a private rental contract when i moved here, keeping me here for 12 months so i've tried to stick it out but i have to get out of there.
Anyway i have an interview for a new role soon. One which i've wanted to do my all my life.
When they ask why i want to leave after a short time (9 months) is it best to be honest and say they have given me a job i have not applied for (or ever would) and that i've tried to make it work for the last 9 months blah but it's simply not for me or is that too 'negative' sounding?
The new interview is for a job i actually applied for in 2022 but they did say at time role wouldn't start until 2024.
Yup, just keep it objective and neutral as in it usually comes across better if you're not overly negative about your current employer.
Like "the role changed significantly" vs "they lied to me". Maybe (probably) they did lie to you, maybe (less likely) there was genuinely some last-minute organisational issue, but just keeping it factual comes across as a bit more professional.
And then just put some emphasis on how the new role is much more in line with what you're passionate about etc..
When i first got there and they told me i did think it was just extremely bad luck but i later discovered, as a matter of fact, i was never going to get the job i applied for even at the time when they interviewed me for it, they knew then i was never going to get that role i applied for so that made me angry when i found out and made me decide to leave.
I would not say "they lied etc" but thinking more along the lines of "when i got there they told me there has been a organisational restructuring and my intended role doesnt exist anymore and they given me an unrelated role which i''ve tried to make work etc" ( this is what they told me on day 1 and i know to be untrue now factually)
As for why i want the job with the new company, no issues there, hopefully my authentic eagerness and interest in the role shines through!
Yeah, just say that. You should be fine.
I'd keep it brief personally, and don't be negative.
Is there any kind of white(ish) lie you can say?
.....I thought the commute would be ok, but turns out longer than I thought, this place is much closer.
The new job won't be in London.
Im nota good liar. I will just say they made changes and put me in a totally different job to the one I applied for and I've done my best to make it work etc.
Which is the truth
Similar to what others have said, I would say something like
The role wasn't what I thought it was and there didn't seem to be any potential for improvement, I then saw this role and was excited to see t and thought that this is the perfect fit for me to help grow and show my potential to your company
That's a pretty terrible idea. Shows a lack of forethought and planning, an issue entirely of your own making.
OP just be honest, don't be overly negative, just explain that you moved for a role that wasn't as advertised and you needed to stick it out for the duration of your tenancy.
I'd tell them that the job wasn't what you expected from the interview but tried to make it work etc.
Be brief and positive though - the idea of this question is not investigating the story/truth of what happened (they don't care about other companies) but it's more about checking if you're a negative person or stupid enough to give a silly reason (i.e. was sick loads, was late everyday, everyone hated me, manager was rubbish, rejected WFH requests etc.). This does happen when I've asked it!
I am going to be honest and stick to the truth and not linger on it too much. I've done nothing wrong.
Despite how they did me over I've remained completely professional. In fact, so much so they have just named me as an exceptional employee in the bi-annual company awards.
They are giving me a pay rise too based on this but while I appreciate the recognition and pay rise, I value my happiness and sanity more.
If I don't get the job from this weeks interview I will just keep plugging away at other applications.
“My current position is not what I was led to believe I was applying for. I’ve tried to make it work for both me and the company. Unfortunately it’s not working out so I’m looking to move on.”
Keep it simple and keep your emotions out of it. I doubt the interviewer cares too much but they will make a black mark against you if you start slagging off your previous employer
That's very much along the lines of what i'm planning to say.
On the other hand he went to great lengths to take the job. I wouldn't make a big deal of it, as someone domestic situation is really irrelevant to most companies.
Whereas a role not being as advertised is as old as the hills.
Really? I've never applied for a job and been given a totally different one before. I'm in my 40's so not my first job. Roles not being exactly as described sure, but completely different and unrelated? Never happened to me until now. I wouldn't have moved if they told me what the real job was doing but it's all done now.
Already lots of good advice, I’d just like to say good luck at the interview
Thanks, bricking it as we speak :D 1 hour to go.
I had a similar experience around 7-8 years ago; moved to a new company to reduce my commute and to break away from 24/7 on call commitments which I had been doing for several years. The day I started the new role they told me I'd be working in a different location to that agreed (longer commute than expected) and that I would be on call with immediate effect. They actually told me straight that they had lied about the details of the role as they knew I wouldn't have accepted the position otherwise. I stuck it out for a few months, but it was not what I wanted and trust was broken from day 1.
When interviewing for my next role, I very simply stated that the reason I was leaving was that the role was not as advertised and the new employer actually took this as a positive. You don't need to give all the detail, just a one liner delivered in a proffesional manner.
Realise this is a bit late, but hope the interview went well!
Thanks for well wishes, 5 minutes before interview started they told me it could no longer go ahead today and they will contact to reschedule.
That's really bad form, especially if that was an in-person interview and you'd got suited up and traveled to their location only to be fobbed off, I'd be tempted to tell them to forget it tbh.
I guess maybe understandable if the interview was scheduled for 9am and the interviewer has just called in sick or has some family emergency or something. Otherwise, this is the sort of thing they ought to drop everything else for else they're not taking hiring seriously. Doesn't matter if they've forgotten or if there's some critical production issue or whatever, there should be other employees available and the interviewer should drop everything and go meet the prospective candidate.
