Poll: Invert Controls
Do you play with inverted Y axis?
  • No, I'm normal.
    Votes: 64 59.3%
  • Yes, I'm a freak.
    Votes: 44 40.7%
  • Total voters
    108
I like my flight sims, and inverted feels right on them. But inverted up/down on an FPS? No chance, you are all freaks.
i'm an invert freak :)
honestly get so confused playing any game when i have to push up to look up.
up = down always!!! :D
Invert is the only way for me!
Because I seem to play like the stick is 'attached' to the camera and i'm holding the back. Pull the back (stick) down and the front (camera) points up.
Also, If you try to look up, you tilt your head back. If you look down, you tilt your head forward. Same with inverted controls. In fact, that's a better example than the stick one I just mentioned :p
Other people just see it as a pointer and pushing up moves the pointer up, down makes it go down.
edit - though I see people mentioning having inverted on PC FPS. That's just freaking weird.
