- 19 Feb 2006
- West Mids
Im trying to setup an IP camera using my static IP address.
With it being static I thought it would be quite easy, but along with a lot of other people, I can't view the stream from outside my own network.
Here is a shot of what the camera is complaining about.
It says that my subnet mast address does not match when as you can see, they do.
Any suggestion welcome.
I have also set the cam to use port 85, so would this be the corect setting in the port forwarding page of the router?
Then to view the cam it would be "my IP":10123
