what monitor will you be using.? and operating system.?
Your basket
Product Name Qty Price Line Total
Sapphire ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail (11133-00-20) Sapphire ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail (11133-00-20) £145.99
(£167.89) £145.99
(£167.89)
Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB) - Retail Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB) - Retail £139.99
(£160.99) £139.99
(£160.99)
Biostar TPower I45 Intel P45 (Socket 775) PCI-Express DDR2 Motherboard Biostar TPower I45 Intel P45 (Socket 775) PCI-Express DDR2 Motherboard £99.99
(£114.99) £99.99
(£114.99)
Corsair TX 650W ATX2.2 SLi Compliant PSU Corsair TX 650W ATX2.2 SLi Compliant PSU £62.99
(£72.44) £62.99
(£72.44)
OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Dual Channel Platinum Series DDR2 (OCZ2P10664GK) OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Dual Channel Platinum Series DDR2 (OCZ2P10664GK) £47.99
(£55.19) £47.99
(£55.19)
Samsung SpinPoint F1 640GB SATA-II 16MB Cache - OEM (HD642JJ) Samsung SpinPoint F1 640GB SATA-II 16MB Cache - OEM (HD642JJ) £46.99
(£54.04) £46.99
(£54.04)
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £16.99
(£19.54) £16.99
(£19.54)
Sub Total : £560.93
Shipping cost assumes delivery to UK Mainland with:
DHL @ Home Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.99
VAT is being charged at 15% VAT : £85.49
Total : £655.41
complete with case and mouse
get 4870 1GB or GTX260 216 core if you are using 1920x1200 or higher res
Sorry to ask again mate but do you think i would be better buying a monitor as well would i still be able to use HD graphics ?
Very similar specs to be honest, just have to get the motherboard, cpu and ram combo correct for your individual needs (and monitor lol)Nice one mate Cheers For that both specs where good but i think am going to go with Kenny's when i get paid Cheers Mate
he hasnt said what resolution the t.v is, it might not be 1920.
also i would probably go for 1tb samsung and spend only half as much on memory.
i would probably stick to a single 4850 or a 1gb 4870 if the hdtv supports 1920.
tbh i would probably make 1 or 2 other changes but i dont do spec me's.
i really shouldnt be here should i![]()
Once I have ordered parts i will do a before and after
