Imo no, the 5700xt will only get better with age...
NV don’t generally care about last gen and performance slips off...
I tend to put this into the category of 'received wisdom' rather than actual fact.
They don't add support for new features on older cards either :/
When Vulkan was released AMD cards going back to like 2009 could support it.
Oh boy, you're gonna get rabid AMD fans telling you one thing, and nvidia fans telling you another...
They appear from a few comparison sights to be pretty much equivalent cards. The RTX 2070 will give you some amount of ray-tracing ability that's not present in the 5700XT, and the 2070 will give you g-sync. The 5700XT will probably give you better freesync compatibility. Either one is going to be a really good boost compared to the current card you have, around 100% boost AFAICT.
They are both very much on par with each other performance wise. So the choice is yours.
Depends on the model in question. For a decent well reviewed model, with decent cooler you are talking a very similar price point.
And again as above the RTX card has some extra features. But it will be limited considering Raytracing performance in general.
If I am strapped for cash I might buy a lower spec card... But I think I will be buying it on the "never, never" (paypal credit), as I like to keep my hardware untill the bitter endIf you don't game too much consider buying a 1660 Super now for around £230. It will be way faster than your 290 while been a lot quieter and using less power.
Either keep it for a couple of years, or sell it when the next generation GPUs come out and upgrade to one of those.
Im not a big gamer no, and the games that I play( most demanding games I have are doom 2016 and dirt rally) run smooth enough, so yeah I can wait. But saying the RTX 2070 looks a nice price at the moment.
I said in a post I would be keeping my r9 290 but its getting hot for some reason, I try to use my stuff until they are slow and chuggy. So Im guessing with not being a big gamer, a RTX 2070 or 5700xt should last me 5+ years until things get chuggy.So you aren't a big gamer.
Your current card runs all the games you play fine.
Yet you want to buy a new gpu?
Do you buy a new washing machine every few years just for the fun of it too?
Take it apart and repaste it. Nothing to lose if you are planning on getting a new card anyways. If it works then it buys you some more months for the next gen card to arrive.I said in a post I would be keeping my r9 290 but its getting hot for some reason, I try to use my stuff until they are slow and chuggy. So Im guessing with not being a big gamer, a RTX 2070 or 5700xt should last me 5+ years until things get chuggy.
Interesting. Tried different pastes?I have done that loads of times, and the first few hrs after reapplying the paste, temps are fine and then they slowly increase again.
The drivers can hardly get any worse
At the resolution you play at and the fact that you are not a big gamer, a 1660 Super would probably last you 5 years no problem. I wouldn't buy any GPU on credit. Start saving now and buy one when you have the money.
Forgetting the price (because I agree the price increases are horrible) I think past upgrades from the 500 series cards and upwards have been ok.Why?
If I know Nvidia (...and I think I do). The 30 cards will be a small improvement, and a significant price hike. Unless pushed by a competitor Nvidia always give the absolute minimum and charge the absolute maximum.
