I think my fears of failing Ballistix are comming true. Here are my Prime logs when I tested with my Ballistix I thought might be failing:
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1951 Time: 15
CPU: 2295MHz FSB: 255MHz [255MHz x 9.0 est.]
3/1/2006 12:15 PM Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
FATAL ERROR: Rounding was 0.4970703125, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 9 minutes 45 seconds - 1 errors, 0 warnings.
Execution halted.
CPU: 2249MHz FSB: 250MHz [249MHz x 9.0 est.]
3/1/2006 12:28 PM Beginning a continuous self-test to check your computer.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Torture Test ran 3 minutes 24 seconds - 1 errors, 0 warnings.
Execution halted.
3/1/2006 3:00 PM Beginning a continuous self-test to check your computer.
Torture Test ran 10 minutes 45 seconds - 1 errors, 0 warnings.
Execution halted.
I decided to try one of my old 512 PC3200 sticks of Samsung and run the same test at the same speed(I used a 166MHz divider and 3-3-3-8 1T in order to get a stable 250fsb)
I put the Samsung ram into my PC and set the fsb to 250 and also put the Vcore down 0.02v and When I came and checked on my computer next it was over 3 hours later and the prime blend test was still running fine. Does this verify my Ballistix are crapping out???
