Is my system worth overclocking?
29 Sep 2013
First off i am new to this forum and if i have done anything wrong please tell me and i'll try and fix it. I was wondering and wanted some advice (as i am not good with computers) if my system is worth overclocking as when i like to play games i like them to look the best they can, I think my PC can handle crysis 3 and BF4 max at the moment but i am not sure. Also i have been getting some stuttering issues on some games such as spec ops: the line, dark souls and skyrim. All minor but noticeable, taken it in to a pc shop several times they've checked everything and stress tested it. So i was wondering if overclocking would help/fix this.
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: Default System BIOS
Processor: AMD Phenom(tm) II X6 1100T Processor (6 CPUs), ~3.3GHz
Memory: 8192MB RAM
Available OS Memory: 8192MB RAM
Page File: 3258MB used, 13122MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
Card name: AMD Radeon R9 200 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6798)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6798&SUBSYS_3001174B&REV_00
Display Memory: 2797 MB
Dedicated Memory: 3054 MB
Shared Memory: 3839 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: PLX2472HD
Monitor Id: IVM6106
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Description: 1 - PLX2472HD (AMD High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: AtihdW76.sys
Driver Version: 7.12.0000.7717 (English)
Driver Attributes: Final Retail
WHQL Logo'd: n/a
Date and Size: 9/24/2013 14:53:50, 94208 bytes
Other Files:
Driver Provider: Advanced Micro Devices
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
One more random question if i wanted to upgrade in the future, could i just get the same or similar card and use crossfire to get the same power boost as getting a better single card? any help is greatly appreciated, thanks.
Memory: 8192MB RAM
Monitor Id: IVM6106
Output Type: HDMI
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
What motherboard, psu and cooler do you have.
Would upgrade the motherboard before clocking. You might manage a mild one but the VRMs on that board are too weak for a decent phenom 6 core clock imo.
