** ANYONE WHO GETS ACTIVATION ERRORS **
afaik this little trick only works on windows!
-close down iTunes, and disconnect your iPhone/Touch
-Fire it back up, and connect your back your device.
-When it tells you that there is a new update available and do you wish to install it, press okay.
-While it is saying unpacking firmware, DISCONNECT YOUR PC FROM THE NET. you have to be quick, it only says this for a couple of seconds.
-Voila! your device will skip past calling home, and will continue to install the new firmware!
installation takes around 10 minutes, do not reconnect the internets until your back on the home screen in 3.0.
enjoy guys!
