- 24 Nov 2002
- 38.744281°N 104.846806°W
The thing is, it's quite an unpleasant feeling (imo) and prolonged it makes most people vomit. I used to be able to take about 45 minutes of light aircraft flight before I started to spew and the acrobatics would trigger it at the snap of a finger
The Magic Carpet ride at Alton Towers when it comes downwards feels pretty much the same as weightless.
I think jumping from a balloon gives a better impression of zero G than a plane.
The ground isn't *normally* an issue![]()
Does anyone know a makeshift DIY home jobby way of getting the same effect?
This is about as real as you'll get, without going on the vomit comet.We used to play in a high speed lift during our lunch breaks. It was one of those lifts that didn't stop for about 20 floors, so it dropped quite quickly for quite a long time. Jumping up in this makes you weightless and is fun, especially if you've been to the pub first.
You do realise that there really isn't such a thing as zero mavity as regards astronauts in orbit?I think too many people are confusing being suspended in the air with the effects of near zero g. It's quite shocking actually.
Sad part is you can't work out the jokers from the serious people(almost)
All they're doing is permanantly falling at the same speed as their surroundings which otherwise makes it look like they are floating.
Ball will keep you isolated from the air rushing past and for a few seconds you'll be weightless.
jump from a stupidly high buiding.
