Is there a way to experience Zero mavity without......
All you have to do is find a way to neutralise the force of mavity. Should be simple enough. I'd start off with apples, science is always a little ironic like that.
lol!!! This get's my post of the week award :)
The odd thing is you'll probably end up being right as well....
I said near zero mavity.
Also where did I mention zero g in orbit of earth?
If anything your reply is almost non sequitur.
Also they're not just "falling" they are moving horizontally (which is not what the term falling suggests) at a great speed at a given altitude, depending on the purpose.
I don't posses a degree or close to further the discussion but even I know that :)
The bit that makes them appear to be in zero g is the the continuous acceleration towards the Earth ie falling, that the spacecraft and the astronauts experience.
Why do you think using the aerodynamics of a ball to push the air around your body makes you weightless? Even as a joke it doesn't make sense.
What do you think those planes are doing when they get up to umpteen thousand feet then drop sharply to allow you to float for a short while.
Oddly enough that part wasn't a joke. You would "float" in the same way.
Are you telling me, honestly, that you believe that a;
Ball will keep you isolated from the air rushing past and for a few seconds you'll be weightless.
is similar to the aircraft maneuver below?
Parabolic arcs in an aircraft are completely different things, you cannot reproduce that effect in the manner you suggested.
The point is that you are moving with an object which alters is direction enough that it's contents are in free fall. Many people get nausea from this effect, an effect you don't get by simply falling from a stand still.
Having an object infront of you shielding you from the elements of air rushing past does not make you weightless.
Eat magnets. Stand above a large superconductor.
Magnets actually isn't a bad idea. If you could find some way of making yourself repel against a lot of magnets inside a sphere in a controlled manor then, you'd be hovering sort of? Like those trains? :p
If you are in a black box, ie no windows, and the box (with you in it) is in freefall, can you tell the difference between freefall and zero-g? ;)
The effects of air resistance on the outside of the box will prevent you from experiencing all but the briefest amont of "zero" mavity.
The closest thing that I an think of replicating the effect of zero mavity using "everyday" situations is falling in a very tall lift. You will fall at the same speed as the car that you're inside and therefore would seem to be floating, it'd be very short and quite fatal though, assuming you haven't rigged something to slow you down safely.
didn't read the thread so could have been proposed before
mavity cat is simply falling, the video is rotated 90 degrees.
Astronauts use swimming pools to simulate space walks so I guess that's the best you're going to get.
Can't you levitate a frog with powerful enough magnets because water is slightly repelled from magnets of something? If so, then an even bigger magnetic field (steal some of those LHC magnets) and presumably it would work on a human?
