- 19 Oct 2002
- Torbay, Devon, UK
as title really. Or is flashing the bios the only way, to cure the powerplay crap.
It seems strange how last night I was reading a thread that suggested that the 5850 was and upgrade from a 275 GTX? It sounds like the 5*** series have more than an issue or two.
Do at little research and you will find the correct way to disable powerplay with afterburner.
1.Navigate to the MSI afterburner folder in programe files.
2.open the MSIAfterburner CFG file with note pad.
3.Look up EnableUnofficialOverclocking and change the value from 0 to 1 save and exit, restart afterburner.
4.For it to work you need to overclock your card, anything over the default clocks will disable powerplay.
my asus 5850 doesnt flicker at stock settings. only when overclocked.
I run 2 screens.
Try turning your overdrive off.
I run 2 screens.
