Pasq mate just staring out one letter will earn a suspension
How many watts is it![]()
he said 1000w, but what make
)Google shows it as having '20 amps per 12v rail. It wouldn't power a 275 gtx.
If it would'nt power a GTX 275 then, it would'nt power a GTX 285.
Try and download drivercleaner. Then put on the latest WHQL drivers from Nvidia.
I used drivercleaner, it did the job with uninstalling ALL NVIDIA products and I was able to re-install it again. So from my personal experience I haven't had any problems.
I have been told on another forum to try a whole load of options - basically to uninstall everything to do with NVIDIA via the control panel, then the registry, delete any key files that windows keep on here to do with NVIDIA, delete the folders manually in the programme files. reboot. then re-apply everything and it should all work out!
So going to give this a go later on tonight, if it fails me now, i think i'll try putting my gfx card in another computer and see what happens...
If i was you, putting a different GPU in to see if it works would be the first thing to do...
Then you know for sure it is your card that is causing the problem...
I have a oced gtx285 running fine on my 600wat psu,but if it only has 20amps on the 12v rail then that could be it,you sure there is not more then one 12v rail coz 20amps seems VERY low for a 1k unit.
