Issue?
31 Aug 2011
Help!? I put a usb into my new build - it wasn't reconising also it has malfunctioned my usb!? FYI i put it into my motherboard USB 2.0 port also my drivers hasn't yet been installed!!
Ok... i built a new PC right - i put the drivers onto a USB to install into my new unit and it fried my USB and now when i put it into my current PC it says it malfunctioned......
Nope, but the USB got extremely hot - the light indicator on the usb show it active never appeared and know when i plug my usb into my current pc i am using which i transfered the drivers it says " please consult with your device manufacturers for assistance getting this drive installed" because it failed...?
dont know, it could be the build, or it could have just been the stick, you wont know til you try another, if that dies then its the build, if it doesnt then it was the stick
depending on the mobo/bios you may be able to manually adjust (lower) the USB voltage in the BIOS if it is an issue
