- 18 Dec 2005
- Londontown
De-Ionised water from Tesco ***
69p per litre ![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Arthalen said:Fraid so at the moment. Any higher and the voltage its taking to get it stable is making temps high enough to start throttling.
Admittedly, I was trying to get stable at 3.8, a largish jump up from 3.6, but I'm happy with air cooled 3.6 and being rock solid. I can play hours of FEAR or DDO and not a single problem.
Also, FEAR detects max settings for my CPU at 3.6, so I'm happy.
I'm currently looking to expand my setup now with water cooling and an X1800 GTO!![]()
jidh007 said:De-Ionised water from Tesco ***69p per litre
Mr Mister said:it looks like **** in the pipes but otherwise good work. Altho ive had more in the lanboy...
FishPolice said:Looks really nice setup for such a small outlay. I'm rather tempted to try this myself at some stage. Guess having a side window is pretty essential though.
What are you using to check temps? Not heard of internal cpu temp before (bit of a n00b tbh).
Townlea said:What Cooler did you used to have?
locutus12 said:i didnt, this is my first, hence why i am excitedi was on air cooling before.
Townlea said:I am thinking if its worth upgrading to this...
My current CPU speed etc is... 2.6ghz (not my max but day to day)
Idle = 29C and 42C underload (Freezer 64 (not pro)) @1.39v
I don't know if it would be worth getting @ £55![]()
...Thing I noticed is your watercooling CPU, GFX and Chipset .... If I just watercooled the CPU.. It may knock my temps down a little![]()
locutus12 said:im only water cooling my cpu, its the main source of heat in most systems, add water cooling to take care of the cpu and as a result you wont have your cpu dumping all that hot air back into your system which results in a temp decrease across the board.
Townlea said:Ahh I see ... hmm probably have to save £250 for a custom WC kit then![]()
locutus12 said:why?this kits given fantastic results just simply cooling the CPU
