ITS TOO DAMN HOT
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Its far too hot.
The OcUK HQ office is like a sauna.
So we went and made a load of fan bundles based on our best selling fans.
Three Fans + Tasty Discount = Cool System
Ideal for watercooling rad upgrades or just a total system overhaul.
Wade in.
Three Fan Bundle - Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin @ £39.95 inc VAT
The GentleTyphoon achieves high airflow volume and low noise with the newly designed impeller, enabling silent cooling of the latest devices which run very hot.
The GentleTyphoon has a different type of tone. The fan propeller is designed to reduce the disturbing frequency fan noise to human ears. The newly designed motor and motor support mechanism of the GentleTyphoon uses a double vibration reduction structure. The new support mechanism uses coil dampers to greatly reduce vibration.
Specification:-
- Manufacturered in Japan
- Only 21.0 dB(A) at 1850 RPM
- Weight 200 g
- Dimensions 119 x 119 x 25 mm
- Air volume at full speed (12V), CFM ±10% 58.0
- Noise level at full speed (12V), dB(A) 28.0
- Fan speed at full speed (12V), RPM ±10% 1850
- Bearing Type Double Ball Bearing
- MTBF 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories 4-pin Molex Adapter, 4x Screws
Only £39.95 inc VAT.
ORDER NOW
Three Fan Bundle - Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM @ £24.95 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
Specification:-
- Super silent APACHE fans in Black Stealth colour
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Only £24.95 inc VAT.
ORDER NOW
Three Fan Bundle - Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin @ £29.95 inc VAT
High performance 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. Killer Viper yellow colour makes this fan distinctive and unique.
Specification:-
- High performance 12cm fan in killer VIPER yellow colour
- Dimension: 120 X 120 X 25mm
- Fan speed: 600 -1900 RPM
- Max airflow: 83.63 CFM (141.75 m3/h)
- Max static air pressure: 2.98 mm H2O
- Noise level: 6.9 -28.9 dB(A)
- Fan life expectancy: 50,000 hours
- Connector: 4pin PWM
Only £29.95 inc VAT.
ORDER NOW
Three Fan Bundle - Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan - 3/4 Pin @ £38.99 inc VAT
High performance 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
Specification:-
- High performance 14cm fan in killer VIPER yellow colour
- Application: PC case or heatsink fan
- Dimension: 140 X 140 X 25mm
- Fan speed: 600 -1600 RPM
- Max airflow: 110.61 CFM
- Max static air pressure: 3.12 mm H2O
- Noise level: 12.5 - 26.01 dB(A)
- Voltage rating: 12V DC
- Bearing: HDB (Hydro Dynamic Bearing)
- Product code: AK-FN063
Only £38.99 inc VAT.
ORDER NOW
Three Fan Bundle - BitFenix Spectre PRO 120mm Fan Blue LED - Black @ £30.95 inc VAT
Following the success of our Spectre™ LED Fan Series, Spectre Pro™ LED ups the ante with an all-new design and enhanced performance. The high pressure and CFM design produces wicked cooling and is also perfect for watercooling setups. Its dual frame construction not only looks great, but also helps to dampen vibrations that cause unnecessary noise. Reinforced fan blades prevent warping at high RPM levels, while focused airflow ensures cool air can reach all of your installed components. With FDB technology for low noise and long life, multiple color options, and on-the-fly light switching, Spectre Pro LED is the new gold standard in performance case fans.
Harness the fury with the Spectre Pro LED Fan Series.
Specification:-
- Dimensions (mm): 120x120x25mm
- Current (A): 0.18A ±10%
- Speed (RPM): 1200 RPM ±10%
- Air Flow (CFM): 56.22 CFM ±10%
- Air Pressure (mmH2O): 1.24 mmH2O
- Noise (dB-A): 18.9 dB(A)
- Colour: Blue
Only £30.95 inc VAT.
ORDER NOW
Three Fan Bundle - BitFenix Spectre PRO 120mm Fan Red LED - Black @ £30.95 inc VAT
Specification:-
- Colour: Red
ORDER NOW
You think your office is hot I work in a kitchen with pretty much non working extracter fans and no cooling into the kitchen!
I could however strap one of these bundles onto poles hanging off my hat to cool my face and neck and use the third to put a breeze to my gentleman parts......
The majority of the above are good high pressure fans, ideal for a 120.3 radiator ;)
Sp120's already come in dual packs don't they?
these are our top selling 5 fans.
tbh i want to use this thread as feedback for what you guys would like to see as a bundle!
Akasa piranhas, ive got two at present and ive found them to be much better than the 120mm vipers. Better looking colour scheme too.
