Right then you lot!
Apache Fan specs changed. apologies I didn't see that sooner.
oh and this...
Three Fan Bundle - Corsair SP120 PWM Quiet Edition Fan 4 pin @ £31.99 inc VAT
The wide body, low-pitch blades of the SP120 fans combined with the custom housing provides outstanding static pressure and airflow through heatsinks or radiators. With rubberized corners, a quiet and reliable Advanced Hydraulic Bearing, and PWM support for increased fan speed control, the SP120 truly is the strong, silent type.
Included in the box are the three user-replaceable colored rings, in red, blue, and white, so you can customize your fan to match your case¡¦s components. Each fan also features blacked-out wires and connectors, so your build looks elegant and clean when done. Available in single and twin packs.
Features:-
- The SP120 High Performance Edition, at full RPM, has outstanding static pressure, up to 3.1mm/H2O, when used on a radiator or heatsink.
- 4-PIN PWM Support for increased fan speed control
- Seven wide body, low-pitch custom blades for optimal static pressure at very low noise levels.
- Custom fan enclosure for ducting air in the right direction with minimal interference.
- Advanced Hydraulic Bearing for reliable, quiet operation.
- Rubberized corners for sound damping when installed with standard screws.
- User-replaceable colored rings so you can match your fans to your case
Specification:-
- Air Flow: 37.85 CFM
- Static Pressure: 1.29 mm/H20
- Sound Level: 23 dBA
- Speed: 1450 RPM
- Power Draw: 0.08 A
**As These products come in single or twin packs you will recieve, 1x Single Pack and 1x Twin Pack
Only £31.99 inc VAT.
ORDER NOW
Three Fan Bundle - NZXT FZ-120 Airflow Fan Series, White LED - 120mm @ £25.94 inc VAT
NZXT proudly introduces its newest series of airflow fans, the FZ-120mm LED fan. The FZ-120mm LED fan is a perfect match for any type of chassis. There are 5 available colors to choose from: white, blue, orange, green, and red. It is ideal for achieving high airflow with minimal speeds of 1200 +/- 20% RPM. The 13 blades provide quiet operation of 26.8 dBA and high airflow of 59.1 CFM. The long-life bearing provides better reliability and extends life span surpassing 2 year warranty. This 120mm fan is the coolest solution for any enthusiast in demand of extreme airflow.
Features:-
- Optimized for extreme airflow 120mm fan with minimal speeds of 1200+/- 20% RPM
- Low noise level of 26.8 dBA with exceptional airflow at 59.1 CFM
- Long-life bearing provides better reliability and extends life span surpassing 2 year warranty
- Available in 5 LED vibrant colors: white, blue, orange, green, and red.
Only £25.94 inc VAT.
ORDER NOW
Three Fan Bundle - Noctua NF-A14 FLX Fan - 140mm @ £54.95 inc VAT
The NF-A14 is a premium quality quiet 140mm fan with a square frame that complies with Noctua's AAO (Advanced Acoustic Optimisation) standard. Its square shape and 140mm mounting holes (124.5mm spacing) make it ideal for use on watercooling radiators or as an upgrade for 140mm case fans. Featuring sophisticated aerodynamic design measures such as Flow Acceleration Channels, the NF-A14 further improves the renowned quiet cooling performance of the award-winning NF-P14. The FLX version provides 1200/1050/900rpm speed settings via the supplied Low-Noise Adaptors in order to provide full flexibility in fine-tuning the fan for maximum ventilation performance or near-silent operation. Its superb running smoothness, reference-class SSO2 bearing and Noctua's trusted premium quality make it an elite choice for the highest demands.
Specification:-
- Size: 140x140x25 mm
- Connector: 3-pin
- Bearing: SSO2
- Blade Geometry: A-Series with Flow Acceleration Channels
- Frame Technology AAO: (Advanced Acoustic Optimisation)
- Rotational Speed: (+/- 10%) 1200 RPM
- Rotational Speed with L.N.A. (+/- 10%): 1050 RPM
- Rotational Speed with U.L.N.A. (+/- 10%): 900 RPM
- Airflow: 67.9 CFM
- Airflow with L.N.A.: 59.9 CFM
- Airflow with U.L.N.A.: 52.2 CFM
- Acoustical Noise 19.2 dB(A)
- Acoustical Noise with L.N.A.: 16.4 dB(A)
- Acoustical Noise with U.L.N.A.: 13.8 dB(A)
- Static Pressure 1.51 mm H2O
- Static Pressure with L.N.A.: 1.18 mm H2O
- Static Pressure with U.L.N.A.: 0.89 mm H2O
- Max. Input Power: 0.96 W
- Max. Input Current: 0.08 A
- Voltage: 12 V
- MTBF: > 150.000 h
- Contents: Low-Noise Adaptor (L.N.A.), Ultra-Low-Noise Adaptor (U.L.N.A.), 3:4-Pin Adaptor, 30cm Extension Cable, 4 Vibration-Compensators, 4 Fan Screws
- Warranty: 72 months
Only £54.95 inc VAT.
ORDER NOW
Three Fan Bundle - Akasa 120mm Piranha High Performance PWM Air Ripper Blade Fan @ £36.95 inc VAT
High performance PIRANHA fan. AIR RIPPER blade design delivers max air pressure, massive airflow.
Specification:-
- AIR RIPPER blade design max air pressure and massive airflow
- PWM with SSC technology provides smooth silent operation
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension: 120 X 120 X 25mm
- Bearing: HDB (Hydro Dynamic Bearing)
- Speed: 600-1900 RPM
- Max airflow: 79.13 CFM
- Sound level: 6.4-27.2 dB(A)
- Max static air pressure: 3.04 mm-H2O
- Rated voltage: 12V
- Connector: PWM-4pin
Only £36.95 inc VAT.
ORDER NOW
