it still needs that pipe to go outside tho right?
or can you just plug it in with its back to wall without pipe and it works?
What would it cost to have a split A/C unit installed? I see that they are sub £500 on Amazon, whether they’re any good or not I don’t know. I fancy one in the living room and one in the bedroom.
Heat exhaustion. Eat something cold.I just scoffed an entire tub of ice cream in one go. Also, I have no idea why I feel a bit ill. It's definitely unrelated...
Cheers. £1200 isn’t too bad if it’s a home you’re staying in for some time. My house is only a stop gap but I may look to have it done when I eventually buy another house.
Heatwave special
Sounds like something I'd like to order in a chippie
I'll take a large heatwave, it'll be a taste sensation.
Yeah you need to use the pipe, very hot air gets pumped out of it - normally you sling it out of the window
[there isn't an indoor air-con unit that exists, that doesn't have that sort of pipe]
Stupid thermodynamics :/Portable heaters can make heat without pumping cold air out, so why a/c cannot work the opposite way without a pipe I dont know.
