itunes problem
22 Oct 2002
Essex, innit?
I have all my music on an external HD.
I've recently got a new PC and syncronised itunes with the HD. ALl the music is there and plays fine.
Except... I am unable to edit any track details (artist, genre etc). It's as if they are write protected, but they're not.
I didn't have this issue on the previous pc using Win XP. This one is Win7 (the only real difference I can think of)
Any suggestions?
Thanks
Urgh. This is definitley smething to do with Win7.
If I right click Properties for the whole Music folder, the Read Only box is checked.
I uncheck it, and Apply to all folders, subfolders and files and it takes a minute or so presumably sorting it.
Then when I go back into the Music folder the Read Only is checked again.
In properties there is a Security tab with multiple "users" and a list of permissions for each.
I didn't set up any users or anything. How do I change all this?
Well if you didn't have write permission on the drive then you're not going to be able to modify any part of the mp3s ie, the tags!
I meant I wasn't sure why Win7 decided, after having all my music on the drive for 4 or 5 years, that it should now be protected and I shouldn't have permission to edit.
