- 23 Apr 2012
- Edinburgh
Asus B760i Mobo (only ITX mobo I have found without a fan)
The ASrock Z790 is heatsink only, but probably not a good choice unless you run at stock speeds.
Yea I don't think that one would even sustain the stock speed of an i7 for prolonged period of time. Bit of a joke of a Z series board.The ASrock Z790 is heatsink only, but probably not a good choice unless you run at stock speeds.
And why is this is on my thread?
I went sf750 because optimumtech can’t recommend them highly enoughI wonder if @Swatmat is sharing the excitement at building a new system in the new Dan case.
What you think of the SF750 he chose? It used to be a nobrainer because of how well it handles GPU transients but there are more suitable options available today like the one you chose.
I already have two SF750s and I'm thinking of using both in a O11 Mini to power two 3090/3090TIs for AI inference. Reading about melting dual PSU adapters and fire hazard has dampened the mood a little but I think it's probably worth doing it with the right dual PSU adapter.![]()
After doing some reading it does seem like the SF750 should be up to the job, although i would get a higher wattage.What you think of the SF750 he chose?
Will that cooler fit in such a small case?Cooler: Arctic Liquid Freezer II 280mm AIO
Case: Dan C4-SFX - Black
Should have made their own thread instead of highjacking yours.And why is this is on my thread?
Your gonna have to give Overclockers a call to find out delivery but I would definitely build up your parts to test.Hey all,
Quick question regarding the C4-SFX case, does anyone know when it'll be back in stock? I ordered all my parts for an ITX build and did the preorder on the case, but wondering if I should just build it in my current case if its got a long time for restock or wait for the C4-SFX to arrive if its only going to be like a week or so?
Cheers
Yeah that was my thinking, I've already put the GPU in the older pc to test. I'll probably bang it together tonight, still waiting on the SF750, but I've got pretty much a brand new RM850x in the older pc. I'll give Overclockers a ring, was hoping someone there that might have see this post.Your gonna have to give Overclockers a call to find out delivery but I would definitely build up your parts to test.
Post here if you find out anything pleaseYeah that was my thinking, I've already put the GPU in the older pc to test. I'll probably bang it together tonight, still waiting on the SF750, but I've got pretty much a brand new RM850x in the older pc. I'll give Overclockers a ring, was hoping someone there that might have see this post.
Sorry, that was aimed at Swatmat. The Arctic is a lot thicker than other AIO's.Yes, a 280mm AIO does fit in the Dan C4
