Caporegime
- 9 Nov 2009
- Planet Earth
Since I am using an older version of Fubar2000 for playback I checked the version log:
http://www.foobar2000.org/changelog
1.1.15
Added basic MusicBrainz tagging capability to the audio CD ripper.
CD ripper can now look up CD information automatically each time a new CD is about to be ripped.
Worked-around shell integration incompatibility with Windows 8.
Converter performance tweaks for multi-core encoding (beta 2).
Resolved incompatibility with Matroska files processed with mkvclean (beta 2).
ID3v2: “rating” tags now compatible with Windows Media Player (beta 2).
Resolved Converter incompatibility with new Opus encoder (beta 2).
Worked-around drag&drop incompatibility with Windows explorer read-only optical media (final).
Added an advanced preferences option to minimize the app on [x] close (final).
Worked-around NSIS installer incompatibility with Windows 8 address space layout randomization (final).
1.1.12
Fixed Musepack HTTP streaming bugs.
Fixed incorrect MP3 decoder behavior on certain rare files.
Fixed crash reporter dialog crash (duh).
Detection of proxy server settings from Internet Explorer.
Fixed multi-channel FLAC encoding (channel mask now gets preserved).
Fixed multi-channel WavPack decoding (channel mask now gets preserved).
Now possible to use HDCD & DTS decoder components with ALAC.
Changed MP3 tag reading behaviors when multiple tags are present.
ID3v2 content now takes priority over APE and then ID3v1.
Various time-consuming operations such as conversion or ReplayGain-scanning now prevent the computer from automatically going to sleep (opt-out).
Tuned ReplayGain scanner for fast multicore CPU / slow HDD scenarios (beta 4).
Fixed Converter misbehavior on files with misplaced “cuesheet” tags (beta 4).
Improved performance when playing MP3 files from internet HTTP sources (beta 4).
Improved compatibility with Apple's HFS driver (beta 4).
ID3v2 handling improvements (beta 5):
Fixed TXXX field name sometimes incorrectly written.
No longer possible to write multiple values per ID3v2.3 frame in various scenarios.
Improved ID3v2.3 specification compliance for TXXX and TCON (genre) frames (beta 6).
COMM frames with a description now show as “COMMENT <description>”.
Certain broken APIC (cover art) frames are now visible.
APEv2 tag writing: relaxed tracknumber/discnumber field content restrictions (beta 5).
Fixed Converter having trouble locating oggenc.exe (beta 6).
Fixed WAV handling exploits affecting versions 1.1.9-1.1.12b6.
Thanks to FuzzMyApp for the report and samples.
Files with .M4R (MP4 ringtones) extension are now recognized (1.1.12 final).
Fixed incorrect handling of hidden files with certain Media Library configurations (1.1.12 final).
There have been converter changes,in the most recent updates and if you start looking at the older updates,there have been changes too.
1.1.15
1.1.12
". Which to the OP's credit is a statement that I think everyone agrees with.
