Introduction
This is my first post on this forum (hello to all) and I'm posting to share the details of what will be my third build, and the first one that I'm starting that will be water cooled from the get go. For the record the first build was a gaming rig that started off as air cooled but was then converted over to being water cooled after about six months; and the second build was a low power home server.
The spec for this build is unquestionably overkill for my gaming needs - I'm essentially a casual gamer - but what this build is intended to do is to scratch my itch to build a new, relatively silent, high performance and aesthetically pleasing system, one that I can put some time into as I don't need to tear down the existing game rig whilst I build this one.
Case & Core Components
Case: bequiet! Dark Base Pro 900 Orange/Black
Mobo: Asus ROG Maximus X Formula
CPU: i7-8700K (OCUK delidded and prebinned @5GHZ)
GPU: 2 x Asus ROG Strix GTX 1080 ti OC w/ Asus ROG HB SLI bridge
RAM: Corsair Vengeance 32GB (4 x 8GB) 3200MHz, RGB
PSU: EVGA Supanova 1000 T2
Storage: 1 x Samsung Evo 250GB NVMe M.2 SSD (for OS); 2 x Samsung 850 Evo 500GB SSD (Raid 0 for games/benchmarks); 1 x Seagate 2TB FireCuda 2.5" internal SSHD.
Cooling Components
CPU Block: Phanteks Glacier C350i acrylic cover & RGB
GPU Blocks: Phanteks Glacier GTX 1080 Ti ROG Strix full water block & RGB
Rads: 2 x Hardware Labs Black Ice Nemesis GTS420
Fans: 7 x bequiet! Silent Wings 3 140mm PWM
Res: EK-RES X3 250 RGB
Pump: EK-XTOP Revo Dual D5 PWM
Hardline: Monsoon 13mm
Fittings: Primarily Monsoon Free Center in Black Chrome
Challenges & Unknowns
1/ Fitting 2 x 420 rads in the case - the bequiet! literature suggests that this is possible with one to the front and one up top but I've also seen lots of folk who have said that this is a challenge.
2/ Airflow - I love the case aesthetics but I've also read that the airflow can be a challenge - I'm almost certain that this will lead me to make some mods to the case.
3/ Power Supply - will 1000W be sufficient? (my current rig is running SLI and has an 850W which runs with headroom so I believe that this should be fine, but some power calculations suggest 1200W or even 1600W would be needed)
4/ PSU Shroud - I plan to build custom cables but I'm still conscious that the lack of a shroud might mean things could look a little untidy. I've a cunning plan on how to address that but I'll keep that under wraps for now.
5/ SSD Mounting - I plan to strip out all of the internal bay mounts and front bays that come with the case to accommodate the rads, res and pump - but that will lead to challenges on where to mount the SSD's - this will likely lead to some mods as well.
6/ Res/Pump Mounting - until I figure out how to accommodate the rads how I mount the res and pumps is TBD, I'm comfortable that there shall be room but with a dual pump that extends beyond the width of a 140mm fan I'm not entirely sure how that will fit in just yet - more modding may be required.
7/ Hardline routing - I'm thinking that I'll feed the GPUs in parallel but beyond that how I route things will largly depend on how/where the rads/fans fit and their orientation.
8/ Cables - this is the first build that I plan to make my own custom cables, so a jump into the unknown for me and therefore listed as a challenge.
Timeline
I expect to have most of the key components with me by the end of this week but I'll need to fit the build in with a full time day job and also some personal commitments over the next few weekends. As such I'm expecting this build to take some time to execute on, quite possibly stretching into February at least. I'm also conscious that I need to curb my natural tendency to "blast through things" and instead try and spend a little more time on the quality of the end result - I'm hopeful that the fact that I have a working system already shall help with that!
Next update shall likely be pictures of the various boxed components - that could be this coming Saturday but that is dependent on some other personal stuff that may need to be prioritised over this.
Cooling Components
Timeline
