- 1 Dec 2015
could always do a route thats basic, clean and gets the job done, any spare tubes, get more playful. least you know you have a set of tubes ready for the rig that does the job !
Are you planning on putting fans in the bottom of the case? I'm putting together a system with this case and wondering if bottom fans will pull in to much dust as mine will sit on the floor.
Plan is to have a total of seven fans: three on each of two 420 rads and one exhaust fan to the rear. The fans on the front rad will pull air in and the fans on the top will exhaust.Are you planning on putting fans in the bottom of the case? I'm putting together a system with this case and wondering if bottom fans will pull in to much dust as mine will sit on the floor.
I thought that it would now be plain sailing but that isn't the case. I'm getting some random crashes, which on occaision leave the board in an unbootable state (Code 00). I say random because I've not found a way to reliably reproduce the issue and it doesn't appear to be linked to any kind of stress - i.e. it's not happening when the system is under load, either heavy power draw or temperature. For example it's crashed twice today after booting up for the first time and doing nothing more than web browsing. I had updated the BIOS yesterday to one that was only a few days old, so I've reverted to an older version but I'm still seeing the same issue. Next step is to start narrowing things down by swapping out stuff - starting with cables.![]()
Yes, no problems _apparent_ when running with air cooling, the caveat with that though is that I didn't do anything more than check that things were functional and didn't run the system for very long once it checked out. And the problem is very random - I had two crashes in the first 30 minutes of use today, and now it's ben running for two hours just fine. The only change for this period of stability is that I'm just running with one monitor, having taken out a small secondary monitor to use with another system - that said there were periods yesterday of some hours between crashes when I had both monitors connected, so I'll leave things running a while longer before I conclude that the issue is linked to that monitor.looking good! did the board work fine in air mode? questing you've tried running everything at 'Default' mode in bios just to see if crashes/boot kicks up a fuss?
As noted above I've had some issues with random resets so, until I've resolved that, I'm not inclinded to add extra uncertainty by adding overclocks. That said I've not had a problem since removing a single small monitor from the equation and having had the system running non-stop for +10 hours during which time I've run benchmarks, played games, installed a bunch of stuff, watched YouTube and just generally messed around. It might be coincidence as I'm struggling to see why that monitor would cause such a problem, but it does seem really odd that with the monitor connected I was having regular crashes, but with it disconnected things are stable. It's not even as if it could be (sensibly) just the extra power draw as I've had crashes with the monitor connected but without the main monitor and a whole bunch of other peripherals too. No problem using that same monitor with any of my other machines either. Very odd. The irony of it is is that I usually use that monitor to keep an eye on system status with HWinfo, so without it I'm missing my usual view on temps etc. Anyways, the peak temp I've seen with the CPU (via the oled display) has been 60C during gaming (Far Cry Primal on Ultra).Nice build mate...what sort of temps are you getting for CPU ? Have you overclock it to 5GHZ yet ?
Sure, hit me up.Hey JayGee, I just signed up for OCUK to reach out. I really like your build, and I've been working on a similar one for the past year. I was hoping to discuss it with you, hear how it's gone over the past few months, and see if I can get some advice.
