This build is now a wrap - a few final pictures start here -> https://www.overclockers.co.uk/forums/posts/34380435/
Thanks for joining me on the ride.
JayGee
++++++ Original log starts here +++++
The excitement and buzz of new generations of GPUs and CPUs has got me looking to launch a new build. This one is almost certainly going to be a slow burner though, to some extent due to the challenges of supply and demand (I've got an RTX3090 on order, but I've no idea when it shall arrive) but also because there is no particular hurry as I'm in the fortunate situation where I don't need to tear down an existing rig in order to build a new one.
Besides the RTX3090 the only other element of the build that is firmed up is the case - a Lian Li V3000WX - which I selected because of its capacity for water cooling, most notably due to the "basement" section allowing for good airflow and thermal separation for the placement of a 480 rad.
Prior to ordering the V3000 I'd compared the dimensions to those of my bequiet DBP900 to make an assessment of how it would fit on my desk and just how much space it would fill. On paper it didn't seem like a significant change of scale[1], but now that I have it with me, I have to say that it really has a significant presence to it!
The rest of the components I'll figure out as a I go but my initial thoughts are:
[1] Comparision of dimensions (in mm)
Lian Li V3000WX 245(W) x 625(H) x 605(D)
bequiet DBP900 243(W) x 586(H) x 577(D)
JayGee
- CPU - waiting on the announcement from AMD on their new Zen3 CPUs - I've not used AMD before but they've caught my attention with all the hype/leaks around the Zen3.
- All of my builds to date have used Asus Mobos so I'll likely to stick with them again for the familarity I have with their BIOS.
- Given the space of the case I'm looking at going with a dual loop setup - which shall be a first for me.
- Provisionally I'm looking at a 480 in the basement for the GPU loop and another 480 up top for the CPU, with Noctua NF-F12 PWM chromax fans on both.
- Aqua Computer for control - see https://www.overclockers.co.uk/forums/posts/34020363 for more details on that.
- For water blocks I'd like to use Heat Killer but they don't currently have any plans for RTX3090 blocks so I suspect that I might use EK blocks.
- For hardline tubes and fittings I've previously only used Monsoon with the acrylic welded collars but getting hold of that kit has been increasingly difficult over the years so I'll likely look for a different solution this time around. I'm currently finding my head turned by the chrome effect brass tubing offered by Bits Power - it looks awesome but I wonder how much I'd miss by not having sight on the fluid in the loop for the peace of mind that it brings.
- NVME M.2 for the OS; SSDs for games/programs; SSHD for storage.
