Yeah, they look gorgeous and the sheer heft of them just oozes quality. I also like that the way the pump attaches to the res you're able to orientate the pump such that you can position the cables in the most convient place to hide them (which is kind of necessary given that the power feed is not sleeved).Really like these, was a toss up between these and Aqualis on my last build, went with the latter and waterfall effect.
In my last build I sleeved the pump cables because placement meant they would otherwise have been an eye sore; but with this build I'll have the ability to feed the cables straight through the back panel and with their placement I'm 99% confident that they'll be out of sight so sleeving won't be a necessity.Surely you mean "given that the power feed is not sleeved.....yet", right?!![]()
I'll see your "plenty of ports to open for fast drain" and raise you a cracked acrylic pipe for instant drain!There's wisdom in carpet-coloured coolant!
Not a problem. I don't know about you but one of the appeals of building is the problem solving along the way. Starting out with an idea of what you want to achieve and then working through how you accomplish that.Ah, good choice!Sorry to try and drag you down with me - but forewarned....as they say!
Yeah, that's fair - and it was pretty much my approach with my home server build, it's entirely utilitarian and sits mostly out of sight - a quick build and the issues I encountered with that were frustrations more than fun distractions.I think it depends on your intentions when you start out. If it's a project you expect to be long and involved and partly done for the purpose of making something challenging, yes absolutely. When it's something "simple" you're just trying to get done, the endless layers of fixing one problem to be able to fix another to be able to even start addressing the issue that stopped you making progress in the first place can be..... frustrating. Lately everything seems to fall into the latter category and the sanity required is a limited resource!
I hadn't considered either of those approaches, but they certainly could have been options. Removing them and rotating them feels like it would have been more faff with a fair chance of leaving things not quite perfect enough though. I'm not quite sure how I feel with covering up the Noctua stickers with something else or nothing - I see pros and cons (with the biggest con that it would force me to be creative (if I went with an alternative design)).Another option for fan stickers upside down is to replace them. Some, I think, have managed to wet them, lift them and reapply (you'd have to check how) but otherwise you can either stick a round black (adjust colour as appropriate) sticker over the top or something with a logo. These days you can probably get some custom printed and cut for you. You certainly can with PCBs as long as you don't mind waiting for them to ship from China.
Absolutely, and I will almost certainly be breaking out both my soldering iron (again) and crimpers before this project is done.Can you solder and/or crimp? If so, you could probably make custom length sleeves extensions and/or Y splitters as an alternative solution....not there's anything wrong with drilling a pass-through.
