The snap-on ones are good.
heh, had to change the battery in one of those last month, it was smoking when used. Pretty sure that's a bad sign.
A decent jump pack would do the job just fine, but a decent one isn't cheap.
If you struggled to start one car from another, it sounds like the leads you were using were crap (too small) or you had a crap connection.
Also if it was completely dead, you need to rev the running car for a bit to get a small bit into the dead battery, sometimes even 3 or 4 mins will do.
Great thing, don't think it's worth carrying one around, tbh the extra weight, you may as well just get breakdown cover...
Extra weight? They only way a few kgs!
You'd rather not carry one around and have to sit and wait for a recovery service to help you? I'd say you were pretty lucky to find an AA van in the car park, how many times will that happen?
Not always the case. The M5 is a real pain to jump - I left the lights on in an airport car park and came back after my 2 week holiday to find the car completed dead, wouldn't even unlock without having to use the key. Called the office who said they get this all the time and said they would send one of their pickups which has a jump pack to get me going. His jump pack was unable and he wouldn't take my word for the fact it was a large engine that took a lot of turning over ("What is it, 2 leetah, mate" kind of comments) before being rude and telling me my car was broke and clearing off.
I called the AA who turned up and the guy was unable to jump me off the AA van alone... but by using the AA van AND a jump pack at the same time was able to get me going.
The only cars that seem able to get me started from a jump are other large engined cars.
I assume then Joshy that the need for a battery with a larger CCA (say 850 in my case) and the fact that a lot of these jump packs are rated for 250/400 CCA is just a complete load of nonsense?
