- 18 Dec 2007
arg ok now cpu temp is around 80. the heatsink is on it ok all down tightly
What is the temp now, did you use paste, how is the heat sink attached to the motherboard?i took it off and put it back on. still turning off
Check the heat sink again. If you've used paste (which you should have) the print left on the heast sink/CPU should be even when you take it off. If you've used screws to attached the heat sink to the motherboard make sure they're tightened evenly.still around 78-80 shuts off at 80
how about the
1.09 v
Did you remove the plastic that protects the three gray strips before you mounted the heat sink? Is the impression left on the three gray strips by the CPU even all the way round?didn't use paste. but the heatsink had three grey strips . the back of the cpu is all greasy.. so some paste stuff was already on it
