Hey guys,
I recently got the Asus Rampage II extreme mobo and with it came kaspersky anti virus 7.0 which i thought would be great.
However it turns out that this version is not compatable with windows7? I'm using windows 7 pro 64 bit and installed the anti virus. The software works but the file anti virus and protective defense features fail to enable.
I did some searching about and figured that I might have to upgrade it to a newer version and transfer my Key but the newer version won't accept my key even though the key works fine on the 7.0 version and so im left with an older version which is'nt fully enabled.
Has anyone got any ideas how i can upgrade it or had the same problem and resolved it?
Thanks in advance.
Thanks in advance.
