what quality wire do they put inside speakers![]()
You all get your knickers in a twist over something you have never experienced. Instead of trotting out the same old arguments why not have the balls to bring your ears and an open mind to a Hi-Fi open day. I'll lay on a range of affordable Hi-Fi gear to see if you can tell the difference between better components. Then we will listen to what happens when cables, tables and handbooks are changed. You can bring your own blindfolds![]()
Those arguments no one ever addresses?Instead of trotting out the same old arguments
An open mind should include the possibility that this might all be a load of bobbins designed to rip off gullible foolswhy not have the balls to bring your ears and an open mind
Unless the cable is pure silver of gold it wont make a hells bit of differance to sound quality and if they are it will only be to certain peoples ears.
ive heard silver actually isnt as good in the long run. same with gold. i might be wrong though.
...which is why I am offering to set up systems for testing. Come along and listen for yourself.Yes, but that principle has never been proven to come into effect at over £1-2/meter
I said that before and it still stands now. I'm not defending Kimber's cable or whether it is value or not - What's perceived as "value" very much depends on the person you ask. Also, I don't have Kimber's cable on hand, but I do have a choice of budget, midrange and quite high-end cables to play around with. ***Come have a listen*** I can say it no plainer than that!You missed the point I was making. No-one is going to tell any difference between this cable and another costing £2/m - unless they've added something to the cable to alter the sound in some way to make it less accurate. How can that be considered "value"?
Yes. Exactly. Thank you! That's the WHOLE POINT!!! Just as one CD player sounds different from another, or one amp to another.It's quite easy to demonstrate that one cable sounds different from another,
A lot of expensive cables deliberately defer from correct resistance, capacitance and inductiveness, tampering with the way a cable would normally do it's job fine in order for them to do things like act as high pass filters, or making the amplifier peak in the treble region, thus changing the sound audibly and making their client base buy new cables all the time in order for them to 'find the right sounding one'.
Yes, absolutely. I suppose it breaks down to how much someone is interested and then what sort of sound they're looking for. Bose would be a good example of giving people what they think is "better" sound - more bass and more treble - without actually improving the things that are really important.lucid - i take it there is a cut off point where you stop seeing the greater quality improvements for the additional cash.
Well you know about the laws of diminishing returns, so we don't need to go over that. But using your car analogy for a second, a Focus RS is a quick car, but a Ferrari or a Porsche will communicate so much more back to the driver about the road and the car's handling. You're getting so much more than just top speed or acceleration. Good music systems and good AV systems do the same too.for example. you can easily hear a massive difference between cheapo satellites and a lower-mid range speaker set (similar to mine) but is a top end system costing £50 - 100k really 100x better sounding? like with performance cars you can get fast as hell for quite cheap, then pay quadruple the amount for a tiny bit more performance.
"Jumping to conclusions" - Not really. If you'd heard the number of systems I have where people have wasted thousands on upgrades rather than getting their current gear to work right then you'dunderstand.Wow, jumping to conclusions there - but surely thats Better that getting your knickers moist over a piece of wire that is worshipped due to its enormous price tag?
Absolutely. There are products promoted by magazine reviews that sound flipping awful. Yet they sell by the bucket load because sheep would rather trust some opinion printed in a magazine rather than their own ears. Take mains conditioners for example. They certainly change the sound, but IMO not for the better.An open mind should include the possibility that this might all be a load of bobbins designed to rip off gullible fools
Come have a listen. It's a simple as that.And repeat the same experiments that have done before and failed to prove anything. It's the same arguments I've heard from homeopaths. If someone wants to sell me a cable costing that much then they'll have to provide some evidence it actually works first - that's not too much to ask is it?
Let's be clear here, just so there's no misunderstanding. Cable choices have to be appropriate to the system. There's very little point hooking up £200 quids worth of QED or Chord if one owns a £100 mini-system bought from Comet or a £300 all-in-one home cinema kit. But if you have listened to some proper Hi-Fi gear at a dealer's place who actually knows what they're doing, and the dealer has been able to show you a sound progression from spending £150 a box to say £300 and £600 per then I think it's definitely worth investigating whether cable can make a difference. Like it or not that £600-£1000 per box price level is still classed as budget gear by many of the leading British Hi-Fi manufacturers.<awaits the next step which will be suggesting I can't afford this/have a rubbish system or some other thing that is totally irrelevant>
Because your brave enough to trust your own ears, and you realise that ABX tests invariably involve the use of a comparator and that ends up wrecking the sound.Why would I want to subject my subjective ears to your persuasion? I'd much rather read of this magical cable being successfully ABX tested.
