Finally, some who gets it.Exactly which is all I gather Lucid has said from the start, value is subjective. Just kinda like wine.
But the point is that to the uneducated pallet does a bottle at £200 / £500 / £1000+ taste that much better than something decent at £25 if you don't know how much each costs? I'd like to bet that the average wine novice couldn't accurately rank wines in order of value, and given the chance to price each according to taste then they wouldn't put values nearly so high on them. Value is subjective, based on experience and personal preference and peer pressure too. Hi-Fi cables are no different.And yes - Lucid is right. Value is subjective. But the comparison between wine is ridiculous - you can taste the difference between one wine and another under controlled conditions for starters
I think most of us "get it".Finally, some who gets it.![]()
There are 3 electrical values which can be measured: resistance, capacitance and inductance. All electrical components (including cables) have these properties and they will measure differently for different cables. You can even design amplifiers with an assumption that cables of a certain type are attached and then use the properties of these cables to ensure amp stability - put the wrong sort of cable on and they can oscillate at high frequencies (above audible ones) and they can overload and ultimately destroy themselves. If you want more information on this then just google "conditionally stable audio amplifier" - one that is stable under all conditions is termed unconditionally stable.I'll try... if someone listened to 2 cables, and said that cable B sounded better because-:
1) It had a deeper bass and more extended treble.
2) The soundstage, in terms of size and depth was wider, taller and deeper.
3) As a result the sound was much more transparent and detailed because there was more separation, or space, between performers allowing the listener to hear more clearly each member of the band sing/play their instruments.
Could science prove that the listener was wrong?
Which is why one needs to sit down and listen to it. No one is holding a gun to anyone's head to say "you must buy these cables". The choice is with the customer. If they're sensible then they'll listen carefully and make a choice based on the benefit that this new component brings to the system.Surely the real issue though is whether or not it actually makes better toast than the £10 equivalent I bought from Tescos, or whether someone (or in fact *anyone*) could taste the difference if they didn't know which machine it had popped up from - if not, then you'd be justified in saying that the £5000 toaster *objectively* represents very poor value for money.![]()
Well I've made the offer enough times here to lay on just such an opportunity.Would be interested in hearing a hi end system though, just to see what it can sound like.
Unless someone reading this thread happens to live nearby and has both the time and inclination to attend, I think purely practical considerations will make it rather unlikely, as I'm sure you're very well aware. With no disrespect to yourself, I'm not going to make a 300 mile round trip to settle an argument with some random stranger on a web forum, particularly when this particular argument has been beaten to death for many years, both here and elsewhere, and still continues to rumble on in more or less its original form.Well I've made the offer enough times here to lay on just such an opportunity.
Anyone up for it?![]()
Are you saying that cables just don't sound different. Or are you saying that they can and do sound different just that spending more than a few quid a metre is just stupid? If it is the second, is that because you believe all cables over a few £ will sound the same?I'd be interested to see you publish your results though, along with your methodology - in particular, what measures you take to preclude the possibility of selection bias.
I suppose it's possible to contrive a situation where certain cables do indeed sound different, but personally I think it's incredibly unlikely that even the goldenest of ears could detect a genuine audible difference between, say, a £1/metre cable and something 100 or 1000 times the price.Are you saying that cables just don't sound different. Or are you saying that they can and do sound different just that spending more than a few quid a metre is just stupid? If it is the second, is that because you believe all cables over a few £ will sound the same?
I t
I'm not arrogant enough to state it as an absolute certainty though, that's where scientific objectivity comes in, as represented by double-blind ABX testing - anything other than truly blind testing will inevitably be subject to the effects of the powerful postprocessor between the listener's ears.![]()
All these car and wine analogies are completely bogus, and altogether missing the point.If they dont try and push the boundaries then what are they supposed to do and I am sure every seller wants their top of the line to be considered better than the competition - look at the competition between Audi, BMW, Mercedes - why do you think Audi bought Lamborghini - to associate the 2, I bet they lose money there or barely break even.
I'm sure it's possible that a very thin speaker cable with very high resistance might fail to deliver the amp's full current, but I'm struggling to understand what other factors could result in a genuinely audible difference. Either way, I'd still maintain that double-blind listening tests under properly controlled conditions are the only way to settle it one way or another.In answer to this try ruinning your systems with thin bell wire from B&Q and see if you hear a difference - then try QED Silver anniversary, then try Chord Oddyssey - evey time you try the new one you will hear a difference for the positive
There is 3 different cable constructions there - they are certainly not selling chinese stuff rebranded (well QED might be but I doubt it)
I could rant at some length about your link, which showcases some of the worst aspects of the audiophile snake-oil industry, but I'll simply ask: Where are the listening tests? What methodology did they use?this is a link to just one of the white paper / tests I was mentioning from Russ Andrews
I could almost 100% say BMW Audi etc couldnt give a crpa what cables go in there cars to the speakers.
Coming from someone who spent 4k+ on in car audiophile equipment they sound good to someone who doesnt know a proper system.
Oh and my friend who won all rookie stages when enter then amature used ebay's finest 16awg speaker cable and blew all the "prestigeous" cables away. It's science not hearing.
What captain is saying is how can 16awg cable be and different from a company advestising "special" 16 awg cable?
It the same gauge and therefore same science applys.
You are not looking at this the right way. That's like (to carry on the car analogy) saying car A is a better drive than car B because it has 50bhp more where clearly you'd also want to know what handling and comfort were like as they feed into the mix.I'm sure it's possible that a very thin speaker cable with very high resistance might fail to deliver the amp's full current, but I'm struggling to understand what other factors could result in a genuinely audible difference.
Nope. 16awg solid core and 16awg multi-stranded have different electrical properties - even if they are made from exactly the same material and construction (except the stranding). See http://en.wikipedia.org/wiki/Skin_effect for just one thing that is affected....It the same gauge and therefore same science applys.
For the love of god, please stop the car analogies.You are not looking at this the right way. That's like (to carry on the car analogy) saying car A is a better drive than car B because it has 50bhp more where clearly you'd also want to know what handling and comfort were like as they feed into the mix.
How do differeng "handling" and "comfort" (which I could easily identify blind, with or without an extra 50bhp) equate to a supposed audible difference between cables if that difference *can't* be identified blind?The second part of your sentence I agree completely with, which makes the first (an unsubstantiated assertion) even more puzzling. You can debate the construction of cables until you're blue in the face, only blind, reproducible listening tests will confirm whether or not that construction actually results in audible differences.The fundamental fact is that different cables will sound different. It might only be a small difference, but the differences are there. The human ear coupled with our brain is an incredibly sensitive measuring instrument.
