I wouldn't go too crazy on units, the worst up to the best are all generally just MDF with a foiled laminate coating. Our LEICHT kitchen was stunning, but even that had a problem witha few units peeling after a few years (swiftly replaced).
Howdens do some nice cheaper units, although recently saw their true handless units and they were noitcably worse than "Ze Germans" and the colours just looked a bit offish.
DIY kitchens are supposed to be good, so might take a look at them at some point.
Stainless steel worktops are TEH ****, won't ever go back to look at all this stone and quartz rubbish. It looks great, gets a great patina over time, is fantastic to keep clean (copper even better for anti-bacterial properties), then did I say, it looks epic!
Here's a low res grab of ours:
We're looking at getting appliances separately. But it's just the things like handleless seems to add a lot of price and the sheer number of units.
This is a rough sketch up of some ideas. Won't do the mirror splashback or the spot lights on the skirting board (led strips on the overhang).
The material choices and the worksurfaces (quartz) seem to really add to the price.
Looking nice.
A few pointers:
- Please don't use a horrible sticky outy American fridge freezer in a brand new kitchen, they look like a cheap tacky after thought. Grab full height 178cm tall, 60cm wide, integrated fridge and freezer units. They then hide seemlessly into the bank of units and you can have the doors mounted both left and right hung, so both can be opened together. If you can budget for it, then just get Liebherr units as they are the best quality out there at an ok price(plus Liebherr manufactur all refrigeration for Miele!).
- Good choice on the LED strips instead of those vile spots in the plinth.
- Also consider a proper lighting plan and different types of lights, not just a grid of spotlights like 99% of builders/sparkies want to put in. Light needs to be where you need it, not in neat symmetrical rows on the ceiling
- To save on a worktop, get that quoted separately. When we had a kitchen quote, the Dekton worktop quote via the Kitchen shop was almost twice what it was from the supplier direct. Kitchen places love things like appliances and worktops to throw a margin onto.
- Don't go for a separate microwave unit, they again look crap and you're adding another rarely (?) used appliances for the sake of it. Look to purchase one of your oven units that has a microwave function. In our last kitchen (the one posted in another thread recently) we had a full size Siemens oven (with pyro cleaning & microwave function), then a compact Siemens oven (with steam and microwave function), then a warming drawer below that. Worked well for parties and most combinations of cooks.
- Get a quooker tap that has the pully outy centre part. It's a godsend for quick washing of parts and means you don't need to use a wavey hand to angle water streams. Can also get the boiling version with a filtered/sparkly water block.
