- 26 May 2018
- Bewdley, UK
Is there a link to the riser cable at all?
Kolink PCI-E 3.0 16x Riser Cable 180 Degrees - 200mm Black @ £19.99 inc VAT
PCI-E riser cable from Kolink, Measures 20 cm, PCIe x16 to PCIe x16, Supports PCIe up to 3.0
Only £19.99 inc VAT.
ORDER NOW
Kolink PCI-E 3.0 16x Riser Cable 180 Degrees - 300mm Black @ £22.99 inc VAT
PCI-E riser cable from Kolink, Measures 30 cm, PCIe x16 to PCIe x16, Supports PCIe up to 3.0
Only £22.99 inc VAT.
ORDER NOW
Both those would be compatible![]()
Case has arrived this morning thanks OCUK.
Opened the box first impressions very smart and well built case can't wait to do the build.
Can't get over the quality for the price the hinged magnetic door is lovely!
Still can't decide whether to get a riser cable or not.![]()
Glad you approve![]()
Certainly doone thing I did notice is no user manual is this common practice these days? I've looked online and the spec sheet is there now no manual available yet.
It depends, but I know there will be a manual eventually, I think they usually have it in like 10 different languages, so it probably takes some time to get ready![]()
It does look very smart!Dammit! I'd of gone for the pink version.
One of my rgb fans has started to rattle any idea about what I'd need for a replacement?
you need to post in customer services with your order number, they will probably say you have to send the whole lot back
It's OK was going to buy it myself just not sure what they are.![]()
