It's exactly that. Just like TCS on a car, 99% of the time the car will never use it. Same on a bike, 99% of the time you will not be using it unless you **** up or are doing a track day.The way I look at ABS is as a back up just in case you cockup. Same for traction control if the system steps in you messed up.
On the clutch of the K the fluid change/bleed made a huge diff.
