I've had an annoying vibration in my car for absolutely ages at about 60-70.
You name it, I've had it done to try and fix it. I even dropped it into BMW to get it fixed under warranty - they said it was wheel balance.
Bit odd that, really, as I'd had new tyres fitted and balancing all round. So I took it back to Kwik Crap and said can you please rebalance. They rebalanced. Problem was still there.
Stupid BMW dealer, I thought.
So I investigated the possibility of replacing suspension arms, etc etc, as 'shimmy' is a common E39 issue. Then someone suggested I got the wheels rebalanced. I wasn't particularly receptive, as I'd already had it done twice, it obviously wasnt wheel balance. It was recommended I took it somewhere with a Hunter Road Force Balancing Machine.
Worth a shot, I thought.
Turns out not many places in the country have a Hunter machine - nearest place was Bentley Westcountry. So I have them a call. Yes sir, we'll balance your wheels. £110.
£110? Yes. £110. 'I only want wheel balance, not allignment'
'Yes, thats just for wheel balance'.
Crikey.
Found a place in Torbay with the same machine - £5 a corner. Much more like it. Drove all the way up.
The wheels were far from balanced - they were WAY out. The guy said they were more balanced without the weighs Kwik Krap had fited than with them! He set it up properly and I drove home..
.... in complete smoothness.
So, moral of the story - even if Kwik Krap will price match Mytyres - which is why I went there - just avoid it. They can't even balance wheels properly.
Crikey.
but since it's so close to my house (can be seen from bedroom window down the road) it's kind of hard to avoid just nipping down then walking home whilst they do what needs to be done ^_^
