laing d5 pump speed
Gabe from swiftech tested the effect of flow on temps a while back over at xs, basically so long as the water is moving it makes very little difference as there is such good flow in modern watercooling components.
Is this right the more Radiators/restrictive things in the line the higher the flow needed? Only asking as I was thinking of having 3 radiators 420,240 and a 140 in my next build.
I found it is entirely based how restrictive your loop is.
As an example:
I am running 2x D5's with the EK tops on the CPU loop.
CPU Block is a XSPC RayStorm and there are 2x 120.1 rads. Initially these were the Black Ice Stealth GTS120 but now are XSPC RX120.1's.
Running both pumps on "3" setting with IBT maxing out 8 threads on the CPU (now a 2700k running at 5Ghz). Changing the pumps from "3" to "5" instantly lowers the load CPU temp by 2C. Cofirmed with Open Hardware Monitor, CoreTemp and RealTemp.
Switch it back to "3, temps instantly go up 2C. Tried this several times with the same result.
This loop is obviously designed for high flow. I am hoping to get my hands on the new Swiftech GTZ block soon. These are MUCH more restrictive so the extra flow is going to be crucial to maintaining a decent temperature.
The myth that a slower flow rate is better as the water has longer to cool down has been around as long as watercooling and pc's themselves. Its all about finding the balance based on the radiators, blocks, pumps and fans you have.
EDIT To summarise, I run both pumps on CPU and GPU loops (4x D5's) all on "5" on foam paddings and they are inaudible.
From my loop testing, every 125Mhz increase in overclock = 1C higher load temps. This is factoring in voltage bumps.
Your only likely to see 10C difference if you have a very restrictive loop.
My point is that adjust your pump speed based on your what you are cooling and your equipment. You will get to a point where the extra lp/h wont make much of a difference as other factors will be limiting you.
Jokesters advice of maintaining about 0.5gpm is spot on for the average WC loop.
No measurably difference to temps between 3, 4 and 5 for me. Two GPU blocks, one CPU, two rads. I run it on 5 as it's still silent, and my flow-meter looks nice when it spins quickly :).
According to those figures, even at the maximum (5) setting, and assuming your figures are UK gallons, the D5 with a Laing top version 2 only pumps at 543 l/h. If your figures use US gallons it's even worse - 452 l/h!
The product specs at OCuK state 1200l/h as the maximum flow rate. Is it your loop that is restricting it that much, or is it possible that your flow meter was not giving accurate figures?
I'm asking as the loop I am building will have 2 D5 with top v 2 in series (for redundancy and extra pressure), and I am using a chiller that recommend a minimum of 1200 l/h flow rate. I need to work out if I should just buy a rad until I have the second PC ready to put in the loop.
