Landscapes + bad weather = meh
20 Oct 2002
London
I'm off on my travels this Sunday (woo!) and am going to be in NZ for the end of their winter. Therefore i'm expecting grey skies and rain, but of course beautiful landscapes. So i'm after some advice on how to make the best of things. :) I might be lucky and get the odd blue sky here and there though, i guess.
Has anyone got any links of pics with bad weather for some inspiration? Or ideas of what settings to try etc.. to try to make the msot of it? Bit of an odd question i know :)
Bad weather can make for a moody picture, with the right landscape you could still pick up some great shots.
As long as it's not just a flat grey sky then yes. They can make very dramatic B&W shots. Think about picking up an ND grad so the grey skies don't end up as washed out white.
Yes, couldy days for the win. Look out for storms brewing or just finishing. Underexpose a bit to retain the sky detail. ND grads also help.
Thats what i'm worried about -- flat grey skies :(
I think i know the answer to this question, but will my circular polarising filter help at all in cloudy/grey weather? I could buy an ND grad, but i'm already bending my budget on lots of memory cards and a spare battery!
bad weather makes for way more interesting images - here are two of mine taken in very bad weather, makes everything look more dramatic. The golden rule is to make sure you dont over exposure the sky however as in bad weather the light tends to be tricky.
yes they are HDR, but especially the first one done with very very mild settings and I then auto leveled and desaturated in PS to bring back the natural look.
Like I said, weather like this is tricky and multi-exposures are almost a necessity to avoid "sky burn"
I really couldn't make my mind up I thought it was either a very well exposed shot possibly with an ND filter or it was very subtle HDR :) Love them both!
Panzer
Yak.
An ungraduated filter allows you to expose the whole shot for a much longer time in good lighting conditions.
It allows you to get 'silk-water' effects and the like without losing the detail in the surrounding landscape etc. The other benifit is you can use a screw-on filter without worrying about the angle the gradient is on. However, as you said a graduating filter is good for keeping the sky and the foreground exposed correctly when shooting landscapes.
Panzer
Ugley_Matt said:
You will have to go for the Mordor look rather than the Shire
that made me laugh :D
Thanks guys, maybe i'll see if i can pick up a graduated ND, otherwise i'll just take care to either expose to the sky or just make sure not to blow it out :)
yak.h'cir said:
Ungraduated? Won't that kinda ruin the effectiveness of an ND for darkening skies relative to the ground?
indeed - I will still process using multi-exposures but as Panzerbjorn says, I want to be able to get some more movement in the landscape images I take.
TBH I can't be bothered with Cokin and graduated ND's, I'd rather just multi-expose.
Ahh thats cool! I know about the uses of ungraduated filters but becuase of the context thought you were planning on using one to just darken the sky while exposing for the ground. :)
I reckon you should give grads a try, once you use them you'll never turn back! They've helped me get some shots that I couldnt have otherwise, and for me at least its much faster to use a filter then doing the whole HDR thing.
e.g:
Could you not get a ND grad screw in filter that rotates like a standard CP filter. A Circular ND grad if you will. As long as there was a mark at the top to show where the dark bit starts it wouldnt matter that you were screwing it in...
*Panzer goes to the patent office*
p.s. Stunning shot Yak :o
Panzer
