Laptop hard disk in a USB caddy?
10 Jan 2006
Bournemouth tbh
I wonder if any of you can help me?
I have a laptop and it doesnt turn on, I think the mobo is dead. The thing is I need to retrieve all the data off of the laptop hard disk!
Is there something like a USB caddy that I plug into a PC with the hard disk in? How well do they work?
Or any other solutions! Much appreciated :)
If you think its dead, cant you just take it out and have a look? Cant really tell from that spec.
Wrt caddies, they are good, you could recycle the hdd as a backup drive maybe?
Ok, ive taken the hard disk out and it does have a SATA port, ive plugged it in, but not detecting, I guess it needs a power source?
Edit: Sorted
