Laptop HDD Problem, I think?
28 Nov 2003
Manchester, UK
Right this has got me stumped.
I am repairing someones laptop and the hdd is dead. I tested the laptop with another hdd and it worked, so I have just bought a brand new 320GB samsung hdd.
When I fit the new hdd I keep getting the message 'No bootable device'. I have plugged this hdd into my PC using an external USB enclosure and it appears fine in there, I formatted it with NTFS. However, the laptop keep says no bootable device found, even if I start it up without the hdd in at all. I am obviously trying to boot from the DVD drive which has the Win 7 disc in, I have tried messing around with the bios settings, does anyone have any ideas???
I have tried everything I can think off with no luck.
EDIT: The hdd also shows up in the laptop bios.
Changed the boot order in bios to DVD/CD first? What make is it? Is there a "Boot Options" menu on POST? HP for example usually have F9 for a one time boot menu, Dell F12, I think
Already have the dvd drive as first boot device.
Where is the DVD from? Is it a genuine hologram disk or a copy? I know it sounds daft but you wouldn't believe then number times people burn the ISO file to the disk as a file rather than burning it as a bootable ISO
Does the DVD boot without the hard disk installed?
It didn't, but it should have shouldn't it? That led me to try something else which has now thankfully sorted it. I borrowed my mates external dvd drive and set that as the first boot device, and it boots from that. I used that to install Windows and all is working now.
