LOL!Don't bother wasting your time on the OP.
Basically what I was trying to show you was that it's probably not possible for the RAM in your 2nd laptop to be running at 667MHz. The speed of the CPU and RAM is calculated by using the base bus speed. In the case of your laptop, it's 133MHz. If your RAM was running at 667MHz, your CPU would be running at 2.16GHz (13*166), which it isn't. It's running at 1.73GHz (13*133). This is all assuming a 1:2 FSB : DRAM ratio, hence the request for the CPU-Z screens...I hope you get whats coming to you douche.
