So SO much "do you even lift bro" stereotypes in this subsection of the forum. Everyone just seems to say everyone's diet is **** but will not follow up on ANY form of advice on how the OP could improve it, the best response you ever get is "ermahgerd sticky thread lift lift bro".
You guys are putting people off posting here. The way I see it, either offer good advice (with reasons) or don't bother posting, what's the point.
[TFU] Thegoon84;24315322 said:_____________________________________________________
There is line... please stop
Right going to give this one more shot….
I tell you while the stickies might be a great read and very informative its extremely daunting and off putting with regards to seeing the walls and walls of texts which are not individual…. Yes yes you reap what you sow. However working 2 jobs with 2 kids whilst trying to monitor a diet can be very very hard.
Anyways….
Saw the dieting stickied thread and have now managed to read thro it all
Questions tho
My BMR after factoring exercise and taking 15% weight loss target off is: 2439.
Am i right in saying:
No more than 2439 cals per day
no more than 180 carbs per day
and no more and less than 30g of sat fats per day?
How much protein in take should I be aiming for? Please don’t say look at stickies as I’m not sure how the others fit together. It’s a mass of information and quite frankly I’m beginning to get lost…. We all still need a bit of personal advice and guidance otherwise whats the point in this section.
To help, i'd hit here:
http://iifym.com/iifym-calculator/
Pop your details in, and if you know your BF% use the Katch-McCardle option.
this will tell you what your BMR is and what to aim for for losing / maintaining / gaining weight.
From there, keep the IIFYM ratio and set them as low as possible (if you are simply dropping weight) and that'll give you how many grams of each thing to eat per day / meal![]()
[TFU] Thegoon84;24315388 said:I dont know my Body fat. How would i find that out?
Keep in mind, the more cardio you do, the more you will have to eat to hit your required calories. This is why I don't really like cardio, all it does it burn energy that could be much better used.
Loosing weight should be slow and steady, you need to avoid the pitfall most fall into trying to create a massive calorie deficit. Your body won't thank you.
I have a little machine I got from the pharmacy that did that. if you don;t know then don't sweat , just use the Harris-Benedict, as it's the other calculator that's in the stickies
They are not accurate.
Another small point:
The only limit on saturated fat should be a common sense one (ie so you don't end up with too many calories). To restrict sat fats means risking missing out on lots of nutrients.
This is when you explain and demonstrate that the best way for him to consume mayo to avoid this problem is via the eye.Got told off by a senior rank in the mess today for putting mayonnaise on my dry chicken breast/salad. "All that healthy stuff and then you put mayonnaise on it... did you know that's basically all fat?".
