Preparations, wow nearly a week of prep work lol as well as waiting for other bits.
Figured I should do an update of some sort & make this as a mini tutorial project interval,
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
not been slacking much at all & this bit took many many hours to do overall although I have been enjoying some more skyrim with some of the time I been waiting for extra supplies
but mostly been preparation work.
3d concept, I keep all individual pieces as groups which keeps them as individual components so they don't become stuck together in the design that are easy to move around so I can just select 1 & edit it whenever with minimal fuss.
Here is how I work out what dimensions of material I need for curve pieces, triple click a curve piece & measure each section on the outside of a curve which gives really close accuracy, would give perfect accuracy but when you get odd measurements like 1.56mm or 1.63 is says it like 1.6~mm so I add up to the closest big measurement which I note as 1.7 to be safe so I work entirely with 0.1mm difference for any pieces like that & then I can sand down the super faint difference to perfection & do the same for any cut outs like the round bars I'll be using on this piece, makes the holes a bit oval when it's laid out in 2d but should allow for the same as the model.
Separating every piece including curved pieces ready for 2d printing on a-4 paper & adding 2 2mm squares with crosses inside them for every joining edge, then finalise the last save with camera parallel projection & then standard camera view as top, ready for layout.
A-4 is 297mm x 210mm but when setting things up to print I pretend it is 280mm x 190mm which prevents where it won't print on the paper so you keep all your needed lines, yes you can choose to print without borders but I think this way give best accuracy especially on a budget printer.
I could give it a bit more than what I do but I like to keep it safe.
Layout which lets you dump your sketchup model & make multi page printable pdf file templates, you don't get this part of sketchup on the free version though but if you look around you can find ways to buy a student license which is a heck of a lot cheaper than the retail version meant for commercial use.
Multipage pdf file ready for printing.
And all the little files ready to print.
Printed all of them & I have them in 2 different stacks, 1 for the gaming rig & the other for the HTPC, next stage is to cut them perfectly with a nice steel ruler & razer, tack them together perfectly measuring all the while & then using the spray glue to mount the templates to the materials ready to cut/drill, think prep work takes the longest to be honest but it should let the progress really flow fast once it's done.
One of the stands side panels after cutting, I have quite a bit of spare 10mm alu from the big cut outs & 1 of the pieces I will make drilling, tapping helpers which can clamp to any panels, even edges & ends of bars so I can drill perfectly where I want to & drill perfectly straight with a manual power drill, so yep more custom tools to be made for doing this how I want it.
Currently at 5 big steps forward & 3 big steps back but with a load of prep work done lol.
