1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Led strip glue + heat = unsticking
Discussion in 'Case Central' started by Devrij, Apr 29, 2018.
  1. Devrij
    Capodecina
    How does everyone overcome this? Whether it's case lighting or behind your monitor, it always seems like the the led strips I've bought eventually succumb to gravity after the warmth weakens the adhesive. Once that happens it's game over as dust gets into the adhesive.
    How do I deal with this without resorting to superglue?
  2. GSXR Gaz Mc
    Hitman
    i used a glue gun on mine just blobs over the top every few inches but i only have them on the back of my desk
  3. xb8browney
    Mobster
    I've got a few trips and I use GORILLA GLUE 3044101 1.5 m Heavy Duty Double Sided Mounting Tape - Clear
    I just cut a few small bits off and it's been solid on my strips.
  4. Devrij
    Capodecina
    That mounting tape sounds good. Have you tried it anywhere that gets warm like in your case?
  5. ree
    Hitman
    buy the magnetic led strips if its for case lighting as they never fall off.
  6. Devrij
    Capodecina
    I Didn't realise that was a thing. I'll definitely check that out as I was after something non permanent and that sounds ideal
  7. ree
    Hitman
    yeah i got the bitfenix alchemy 2.0 strips ages ago they are excellent.
  8. Habakkuk
    Wise Guy
    Kapton tape can also work - it's a thin-film polymer.
    It's heat stable & won't leave residue.
