Left 4 Dead 2 - Frame Rate Issues?
I've started hitting this problem after a graphics card upgrade.
On my old ATI4870 all was fine. Now on my new AMD7870 the framerate at times drops from 60fps to 40fps...
Very annoying :(
I'm surprised ati is getting that low fps. I play with shadows on low, effects high, textures high no AA no AF and am hitting the 300 fps ceiling. That's at 1080p with multi core on. Lots of zombies on screen will drop lowest about 200. Core i7 @ 4.5. Gtx 570.
Try downloading a high fps cfg may help a little, also change your network settings, lerp settings etc. l4D2 isn't set up great for default network settings.
You should be getting around same fps in single player as you do in MP.
I got the same on a heavily overclocked 7850.
Disabling Vsynch ingame cured it for me strangely.
Well, disabling vsync just means the frame rate is 100->200fps, and generally all over the shop. Personally I like vsync on.
And as I said, by playing around with the settings, turning all to full or as good as, somethings fallen into place now, and it sits there at 60fps quite happily.
Very odd! I suspect one particular setting is clashing with the driver and where vsync is enable cause a frame opportunity is being missed, hence a nigh on perfect drop from 60->40fps. (My spider spider sense is tingling around the double/triple buffer option for vsync).
