The new Leica M8 looks totally cool - http://www.leica-camera.us/photography/m_system/m8/. Nice and compact with superb build quality. Could this be the ideal handy camera?
Yes I have a 5D, but didn't go for the 85mm len. It's a great camera but I still find I reach for my Ixus 700 most of the time, because of the 5D's bulk. This is why I'm interested in the M8, although it doesn't have built-in flash.AdWright said:Spie - I seem to remember that you have a 5D and were thinking of getting the 85 L F/1.2 - how are they coming along? Got any photos to share with us?
Spie said:This is why I'm interested in the M8, although it doesn't have built-in flash.
Of course the Canon 5D is much bigger and heavier and has 13MP CCD.Having shot many thousands of frames with the Canon 5D since it came out a bit over a year ago I am comfortable stating that there is essentially no visible difference, especially on prints, even large prints, at ISO 100, 200 or 400. Even at 400 the camera is practically noise free. To its credit the Leica M8 similarly has no significant difference in visible noise at either its base ISO of 160 or at ISO 320.
At ISO 640 where the 5D shows just a smidge of noise, the M8 does show a bit more. Again, nothing to concern oneself with, and really only visible on screen at 100% and hardly in prints. I regard ISO 640 on the M8 as perfectly usable even for critical applications. Indeed, when I convert to B&W, the grain reminds me of a 200 ASA film developed in a high accutance developer like Rodinol. Just visible, but doing more to add texture than be an issue.
The bottom line on noise with the Leica M8, to my eye at least, is as follows. ISO 160 and 320 – no noise whatsoever. ISO 640 – a very small amount of noise which isn't even worth removing. It gives the file character. ISO 1250 – some noise. You can remove it or not. Not a problem, especially in B&W. ISO 2500 – visible noise, but easily cleaned up. End of pixel peeping.
SDK^ said:...you just know it's going to produce stunning images.
cyKey said:Built-in flash should be banned from cameras. The light it produces is just nasty. Better to up the ISO but as Joe says the M8 isn't that super above 360, which is kinda depressing.
