- 26 Apr 2004
- Milton Keynes
@Vandle
If you can, change the order to 4070 with 16GB RAM ASAP before it ships.
Laptop graphics you're more or less stuck with for the lifespan of the machine, RAM can typically be upgraded, so going for more RAM and a weaker GPU is a mistake, especially as 16GB whilst not optimal is still usable. (with the exception of if you need more RAM and your intended machine has soldered RAM). The Lenovo's typically do not.
The 4070 is a decent chunk faster than the 4060 at the same wattage.
